Box Employee
May 27, 2025 12:44 PM UTC
Multi-Factor Authentication Code Set Up Problem
When I try to enable my email multi-factor authentication for my account and follow the "Set Up" instructions, using the following steps:
  1. Go to Account Settings > Account.
  2. In the 2-Step Verification section, click Set Up.
  3. Click Set Up.
  4. Select Email and click Next.
    • The following window confirms you’ll use email MFA to sign in. Click Submit to continue.
  5. Select the email you’d like to use for the Box login.
  6. Enter the code sent to the email you selected for MFA.
Number (4) step does not appear for me to "select email" in order to proceed through the remaining steps.
    1 reply
    Box Employee
    Hi Jennifer,
    Please try your alternate browser and try again. However, if the issue persist please clear your browser's cache and cookies.
    Hope it helps!
