Java box SDK Connection Problem
  • May 22, 2025 6:33 AM UTC
  • 2 replies
  • 124 views
Hi,
I am new to Box and using the below Java code to list out the files in my folder. But, I am getting BoxAPIException as shown below.
Code:
BoxAPIConnection api = new BoxAPIConnection("Developer Token");
BoxFolder rootFolder = BoxFolder.getRootFolder(api);
for (BoxItem.Info itemInfo : rootFolder) {
System.out.format("[%s] %s\n", itemInfo.getID(), itemInfo.getName());
Exception:
Exception in thread "main" com.box.sdk.BoxAPIException: Couldn't connect to the Box API due to a network error.
at com.box.sdk.BoxAPIRequest.trySend(BoxAPIRequest.java:451)
at com.box.sdk.BoxAPIRequest.send(BoxAPIRequest.java:265)
at com.box.sdk.BoxAPIRequest.send(BoxAPIRequest.java:240)
at com.box.sdk.JSONIterator.loadNextPage(JSONIterator.java:74)
at com.box.sdk.JSONIterator.loadNextJsonObject(JSONIterator.java:90)
at com.box.sdk.JSONIterator.hasNext(JSONIterator.java:32)
at com.box.sdk.BoxItemIterator.hasNext(BoxItemIterator.java:28)
at com.visa.sample.FirstFirdayoftheYear.getAllPersonNames(FirstFirdayoftheYear.java:18)
at com.visa.sample.FirstFirdayoftheYear.main(FirstFirdayoftheYear.java:12)
Caused by: java.net.UnknownHostException: api.box.com
at java.net.AbstractPlainSocketImpl.connect(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.SocksSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at sun.security.ssl.SSLSocketImpl.connect(Unknown Source)
at sun.net.NetworkClient.doConnect(Unknown Source)
at sun.net.www.http.HttpClient.openServer(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.(Unknown Source)
at sun.net.www.protocol.https.HttpsClient.New(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(Unknown Source)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(Unknown Source)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(Unknown Source)
at com.box.sdk.BoxAPIRequest.trySend(BoxAPIRequest.java:449)
... 8 more
Any help appricated.
Thanks & Regards,
VT
The error message says that it's an IOException caused by an UnkownHostException  for api.box.com — the docs for that exception indicate that it's thrown when the IP address cannot be resolved for a host.  Are you able to reach api.box.com when making requests manually through a tool like curl or Postman?  Is there a chance you're behind a firewall that blocks access to the API?
Dear All,
I am able to connect Box APIs using PostMan by dev token generated through portal. However, when I try to do the same thing using Box Java SDK, I am getting UnknownHostException for api.box.com and upload.box.com
Since I am able to get response with PostMan, so this certainly is not a network or firewall issue. Only when I am trying to run my java code from eclipse I am facing this issue. Below is the code excerpt which uses SDK -
BoxAPIConnection api = new BoxAPIConnection("CClWUDaNOriFxEljGYGn5hmAwfpwQEUf");
BoxUser.Info userInfo = BoxUser.getCurrentUser(api).getInfo();
rootFolder.getMetadata(); ==> HERE I AM GETTING ERROR UnknownHostException
I also tried to use apache HttpClient with HttpPost by pasting the API and passing token in header. But at that time I get 403 error with reason as access_denied_insufficient_permissions.
Please help in figuring out the issue.
Thanks in Advance.
