Upload file into box without manual interaction using c#.net
  • September 5, 2023
  • 1 reply
  • 475 views
I need to upload file into box without manual interaction using c#.net.
As per the SDK, I need to pass access token & refresh token.
How can I get Access token & refresh token from C#.net using client id & client secret without manual interaction.
Thanks.
1 reply
smartoneinok Box
Hello 👋
You can create a client using the .NET SDK and CCG. Here is a code snippet of doing this.
You can then use the upload method.
Thanks,
Alex, Box Developer Advocate 🥑
