Query string that contain ampersand "&" using box sdk node
  • Apr 5, 2024 5:30 PM UTC
  • 224 views
I am trying to query files based on their metadata template that contain an ampersand ex: “A/7-8&9/389-399” using node box sdk metadata query method but it does not return values. It matches other values that do not have ampersand. Is there a way to handle special characters when trying to query them.
I notice it works only if the query is setup as shown below
       var from = 'enterprise_someid.somekey',
         ancestorFolderId = 'somefolderid',
        options = {
            query : "DocumentId ILIKE :arg1 OR bookAndPageNumber = :arg2",
            query_params: {
                arg1: '%' + params + '%',
                arg2: params
            limit: 10
type or paste code here
If i include the pattern matching operation it does not work
        options = {
            query : "DocumentId ILIKE :arg1 OR bookAndPageNumber ILIKE :arg2",
            query_params: {
                arg2: '%' + params + '%'
            limit: 10,
            //fields:
