New Participant
Mar 18, 2024 7:35 AM UTC
Not authenticated on box using valid credentials
Hi,
We are using jenkins tool to upload files on box folder but due to the below mentioned error box uploads are failing:
Please check the ‘exp’ claim. The ‘exp’ value exceeds the maximum value of 60 seconds beyond the issue time
Please suggest.
Shailendra Jetpuria
1 reply
smartoneinok Box
Senior Developer Advocate
Mar 19, 2024 5:48 PM UTC
I found this older post on the old dev forum - have you tried syncing the time? Looks like that worked for most people.
