Solved
Issue on clearCache method on Content Explorer Widget?
  • Sep 5, 2023 12:38 PM UTC
  • 4 replies
  • 426 views
As per Box documentation, the clearCache function of Content Explorer should force reload the items. But when I call the same function, I don’t see any reload of items in Content Explorer widget.
I am using Content Explorer version 17.1.0.
  • Clears out the internal in-memory
  • cache for the content explorer forcing
  • re-load of items via the API.
  • @public
  • @return {void}
    contentExplorer.clearCache();
Best answer by tjuanitas Box
Hey @Niladri!
I can see where there’s confusion with that comment. The clearCache() method won’t actually immediately re-load the items, it just means the next time a network request should be made, it will not use any cached result.
You can see the implementation of the method here:
View original
rbarbosa Box
  • Developer Advocate
  • Sep 5, 2023 8:09 PM UTC
Any errors on the console?
  • Author
  • Known Participant
  • Sep 6, 2023 10:52 AM UTC
There are no errors on the console.
  • Box Employee
  • Answer
  • Sep 13, 2023 4:31 AM UTC
Hey @Niladri!
  • Author
  • Known Participant
  • Sep 13, 2023 10:39 AM UTC
Hi @tjuanitas,
It’s great to have a better understanding of how the “clearCache” method operates, thanks to your explanation.
