Box Python-SDK oauth error
  • Apr 8, 2024 1:13 PM UTC
  • 1 reply
  • 264 views
Hi, I am very new to using python. I tried to follow documentation of python SDK. I want to use GET / POST requests on box via python.
  1. I am using OAUTH, is it alright? (Or should I use basic auth / JWT - I am unaware of these methods but willing to learn)
  2. Here is the process I followed :
    a) Created a new app in Box Developers with Oauth. I am able to use this clientID & clientSECRET in postman app to fire all API commands. I have generated “Developer Token” as well on this page.
b) Downloaded boxsdk to use it in python environment
Please tell me what I am doing wrong.
What should I use as Auth Code, if not the developer token? How to generate this auth code? Is my redirect URL Correct?
PLEASE HELP!!!
1 reply
rbarbosa Box
  • Developer Advocate
  • Apr 8, 2024 8:53 PM UTC
Hi @rahuldesai , welcome to the forum.
Perhaps you should try a CCG authentication for your Python script.
OAuth 2.0 is interactive and requires user interventions.
Looking at your code, after doing the oauth.get_authorization_url you are supposed to redirect the user browser for them to authorize the app. This might not be practical in your situation.
However I do have some authentication examples to share with you.
For the classic Box Python SDK you can take a look at this GitHub repo, specifically the test_ccg.py, test_jwt.py, and test_oauth.py. These samples are a bit old but they should work, check the requirements.txt for specific versions.
For the Next Gen Box Python SDK, you can look here. Same pattern, take a look at the test_xxx.py scripts.
These are also workshops, see if there is a topic you would like to explore.
Let us know if this helps
Best regards
