Manual Token request, with public key
Hello,
I have been attempting to do a request to :
My dev setup, is almost identical to my prod setup with one exception. In prod i use a Public Key. I am rewriting a tool i made using the NodeSDK in Rust. The issue I have is, in the NodeSDK you can pass it a thing like this:
“boxAppSettings”: {
“clientID”: “hvauxhjq98474895cej49uq2na1k4m3hca”,
“clientSecret”: “********************************”,
“appAuth”: {
“publicKeyID”: “”,
“privateKey”: “”,
“passphrase”: “”
“enterpriseID”: “42069”
Then i just pass it to my sdk as a preConfigured instance. HOWEVER, I have my Rust based Wrapper working with my dev account, but when I go to move into prod, I must be missing something, as i cant find examples of how to do this using a direct http request:
For example:
GitHub - box/box-node-sdk: A Javascript interface for interacting with the...
A Javascript interface for interacting with the Box API. You can find the node package at - box/box-node-sdk
Where is the documentation on this process but with ‘curl’ or some other direct http calls?
I bet it exists but there seems to be no clear linking to it?
Any help and guidance on where to find this information would be greatly appreciated.
Thank you,
Andrew
