Download a folder as a zip using box-node-sdk
I’ve incorporated Box into my applications and have relied on it for several months. Previously, I’ve been utilizing the getDownloadURL function outlined in their documentation to download individual files.
Now, my objective is to download an entire folder as a zip file. To accomplish this, I’ve utilized a recursive implementation of the getDownloadURL function and manually recreated the folder structure to mimic that of Box.
Is there a built-in solution or workaround provided by Box for this scenario? The current process is consuming significant server resources and is prone to failure, especially when dealing with folder sizes in the gigabytes range.
Thank you in advance for your assistance.
