Solved
Can I set up Box Sign with Salesforce using Salesforce tags?
  • Aug 15, 2024 9:59 PM UTC
  • 2 replies
  • 275 views
How can I set up e-signature templates with Box using Salesforce Tags?
Best answer by DavidAtBox
Hopefully this helps https://support.box.com/hc/en-us/articles/19555153787411-Setting-Up-Advanced-Sign-Settings
View original
  • Box Employee
  • Answer
  • Aug 21, 2024 7:21 PM UTC
dzarazua Box
  • Box Employee
  • Aug 22, 2024 6:33 PM UTC
Yes, enable your teams to work directly from Salesforce when requesting signatures and then use SalesForce Flow Support. You can include up to 50 template tags per document to auto-fill from SF object fields
