Known Participant
Oct 18, 2023 11:08 AM UTC
Box Exception when using boxsdk and Oauth2.0
boxsdk.exception.BoxAPIException: Message: Access denied - insufficient permission
Status: 403
Code: access_denied_insufficient_permissions
Request ID: 4j7c94hizkxe10i7
This is the response I get when I call through my application. But when the same call is made through postman I do get the response. Is the problem with the oauth or with my authentication code.
I followed all the documentation lines for the Oauth2.0 in python sdk
    1 reply
    smartoneinok Box
    Senior Developer Advocate
    Oct 18, 2023 7:02 PM UTC
    Hello 👋,
    This error occurs when the user you used to login with OAuth 2.0 in your application doesn’t have permissions to view the content.
    I can only guess that the user used in the Postman environment setup is different that than one in your application - is that possible?
    Thanks,
    Alex, Box Developer Advocate 🥑
