I am displaying the box file information via iframe on Salesforce.
However, because anti-clickjacking measures are enabled on the box side, a screen (attached image) appears to fit into the cloud.
We would like to avoid this screen and display the file directly.
We are assuming that the above can be avoided by setting the X-Frame-Options header, and we would like to know the specific settings and the process.
Workaround for clickjacking when using X-Frame-Options header
Sign up
Community access is available only with a Box Account.
Sign in with your Box AccountSign in to the Box Community
Sign in with your Box AccountEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
