Vision Pro help
  • May 23, 2025
  • 1 reply
  • 65 views
Hi guys, I am brand new to Box so consider this a noob question. I have added a file on my Mac, which is showing up in Box under all files. When I use the vision pro app, however it is not available in any area logged in into the same account. Have I missed the step? Thank you!
1 reply
Hi there,
If I understand this correctly, you're trying to sync Box with your Vision Pro App? It would be helpful if you could share more information regarding your workflow for more context.
We'd love to further assist!
