"Request body ended before we could read expected number of bytes: 33554432
  • May 23, 2025
  • 3 replies
  • 72 views
  1. Hi Team, i am trying to upload part of file in chunks using CURL - i -X PUT "https://upload.box.com/api/2.0/files/upload_sessions/F971964745A5CD0C001BBE4E58196BFD"
  2. I am getting the response below :
  3. { code"request_size_mismatch"
  4. message"Request body ended before we could read expected number of bytes: 33554432"
  5. request_id"1ec295d84ce895a2c8afac9296086604" }
Also please explain to me how to set this below binary file in http header.
--data-binary @<FILE_NAME>
Thanks in Advance.
Rama
Hi,
Can you post the full command you are running?
Thanks,
Alex
Hi Alex,
Actually we are implementing the large file uploads in Chunks .
first step is successful using Create upload session API.
Second step is to make the Upload part of file API using -
 curl -X PUT \
  https://upload.box.com/api/2.0/files/upload_sessions/7B724420D5DE54DF249BE2ACBCFD8261\
  -H 'authorization: Bearer 1!htuiKz568eisdwzIjzSIsqsR5EnmHhkCC3YpM1CHRoNdaZAIDK8BqUTiT2j_qdXk3VEzKYv3qSK0I2rHHWVHzLDbwGFK2PuA4ERyVktij9GlPG5HlPshv-AJitYWn1l-Adcx8Dyyp6IGfsKAgCmM2jxzpZ91cSHlfqcd_b5376tZQLHRBz19UUfx4nXFcAY5rL6n6zGIP13XmSkqtCdlWwy0Q_4oVJIsqvbDI2cdIUV9RlszBA5XgHcKiIkyYFwKwymbs6Ia5mAW_vwSvIyAijipa_Buk3skqI18EB9UYdViJbcDxiJtm5-JObVhzOvBpaXsNBAurR-oZndgStaSBlAR0iKrjWGCZiTTVAs6mrUWq2FdRik_Vru1gM8RHafGjpRoYk74wLiAJXHpEA2tvrNPcRebOLOYSEIr1WC_j2MFT-N7AZ7uMoG3EyAEyod4O-PiYtrNYPMxbuKPN2_Z4rULA0GDgIZlUxNcNwrw98iDrQ6vuNJs9-2P4PgYcdXTmDktGh4CmqXO8HYKpW0oSFEaO643EEyNG4OjCjmQ8BWtoM_bsBZGBptVmQ2yE3icI_MT0_jepT3nDw..' \
  -H 'cache-control: no-cache' \
  -H 'content-range: bytes 0-33554431/3896706048' \
  -H 'content-type: application/octet-stream' \
  -H 'digest: sha=vyGp6PvFo4RvsFtPoIWeCReyIC8=' \
After in the Request body we are sending the file object in binary format.
we got the response like : failed net::ERR_CONNECTION_RESET
I have attached the response in the BOX2_bej8bCM6W5MFjCfe9Pcd7g.pngscreenshot
I would appreciate your review and suggestions. Thank you very much for your assistance.
Regards
Rama
Is it possible that your company has a proxy or something that is restricting your access to upload/download files? That is typically why I see an error like that.
