Problems in uplaoding Files to Box using Curl Calls - API
  • May 22, 2025
  • 6 replies
  • 47 views
Hi, I am trying to implement the curl call for uploading a file to BOX using documentation way but that way we get this response 'API Upload did not contain a file part.' Please responsd as soon as possible. Thanks.
Hi!
Can you send me the syntax you are using for your CURL call?
Thanks,
Alex, Box Developer Advocate
Hi, Thanks for getting back to me.
This is my API call you can clearly see the call and response as well.
BOX__yrXV1cSKMlNHVS0pjM1K4g.pngI am using this CURL given at official documentation.
Please help.
Thank You!
Can I see the body tab? You should be able to select a file.
Hey, Thanks again. I did as you said but here comes another issue:
Ah! the syntax in the value field is wrong.
Try it similar to this:
"name": "Photo.png",
"parent": {
"id": "124132"
Hi,
Thank You so much! Mr. Alex
It is working fine.
