Problems downloading from Web Interface
  • May 27, 2025
  • 1 reply
  • 89 views
Hello,
I need to download data from my account. When I try to download a folder your system generates a zip but download is never completed or file is corrupted. This problem is new. Time ago I didn´t have any problem to download the full content of my account around 10GB. What is the problem now? I need my data
1 reply
Hi Tomas,
If you are encountering problems downloading files from your Box account, we recommend that you try:
  • Updating your browser to the latest version
  • Clearing your browser's cache
  • Using Box with an alternate browser, computer, or network. If possible, Test using both Ethernet and Wi-Fi connections. Wi-Fi is typically slower than an Ethernet connection. Increased distance from your router can further decrease your speeds. If there are walls or other obstructions between you and your router, this could cause your internet speed to decrease. In that case, try moving closer to your WiFi router.
  • Temporarily disabling any internet security/firewall programs to test whether they conflict with Box (Note: you may need clearance or assistance from your organization’s IT department/helpdesk to do this)
  • Temporarily disabling any plugins/extensions in your browser
  • Removing unwanted extensions, plug-ins, ads, pop-ups & malware:
  • To check download performance, do the steps here: Testing your Network Connection.
Thanks for posting!
