Box Employee
May 27, 2025 5:43 AM UTC
Login Box Drive Problem
Hello,
my Problem is with Windows 11 Pro 23H2 and Box Drive.
Box Drive ask me often about Login name and passwort. I must write often new my account Data and the Box Drive then connect again. Can you please fix it and helb me?
best thanks.
    1 reply
    Box Employee
    Hello,
    It appears that you're encountering frequent login prompts with box drive on windows 11 Pro 23H2. To address this issue start by ensuring you have a stable internet connection and that Box Drive is up to date. Check Box Drive settings to verify your account details are correctly saved. Consider ADP Vantage HCM clearing the application cache or resetting Box Drive if the problem persists. You can also check and remove any outdated credentials related to Box Drive in the Windows Credentials Manager. If needed, try reinstalling Box Drive and contact Box support for further assistance if the issue continues.
