Files won't open in Box but will in Box sync, even though I've received messages to delete Box sync, I don't dare. Help!
  • May 23, 2025
  • 1 reply
  • 83 views
I received messages that told me to delete box sync because it was now updated and no longer necessary. However, when I try to open files in BOX they often won't open. When I go back to Sync they will. There are files missing in Box, also. I would have been in a world of hurt if I had followed that message and deleted Sync. What do I need to do to fix these issues? It makes it so my bookkeeper often can't see things I upload.
I need actual help to resolve this!
1 reply
Hi Jean,
We strongly recommend switching to Box Drive.
We firmly suggest for this change in your environment as Box Drive is the current Box desktop experience, does not require manual syncing (though this is available through the mark for offline option), and the issue you're experiencing is likely to be resolved straight away after installation. By installing Box Drive from this link Box Sync will be automatically uninstalled, and any files that had not synced up to Box will be preserved in your old Box Sync folder.
This article explains the difference between Sync and Drive: https://support.box.com/hc/en-us/articles/360043697354-Switching-from-Box-Sync-to-Box-Drive
This article goes into a little more detail about Box Drive and its basic functionality: https://support.box.com/hc/en-us/articles/360043697494
Hope it helps!
