Could not resolve dependency: npm ERR! peer axios@"^0.18.1" from box-ui-elements@12.0.0-beta.9 npm ERR! node_modules/box-ui-elements npm ERR!
  • May 22, 2025
  • 4 replies
  • 80 views
Getting bunch of errors when trying to npm install box-ui-elements for content uploader.
It seems a lot of dependencies are depreciated.  Is this library and package still working?
https://developer.box.com/guides/embed/ui-elements/uploader/
npm ERR! code ERESOLVE
npm ERR! ERESOLVE unable to resolve dependency tree
npm ERR!
npm ERR! While resolving: box-ui-elements-demo@0.1.0
npm ERR! Found: axios@0.19.1
npm ERR! node_modules/axios
npm ERR! dev axios@"^0.19.1" from the root project
npm ERR!
npm ERR! Could not resolve dependency:
npm ERR! dev box-ui-elements@"^12.0.0-beta.9" from the root project
npm ERR!
npm ERR! Fix the upstream dependency conflict, or retry
npm ERR! this command with --force, or --legacy-peer-deps
npm ERR! to accept an incorrect (and potentially broken) dependency resolution.
Hello,
Is this happening with vs 13.0.0 too? It looks like the vs you are installing is a beta?
Thanks,
Alex, Box Developer Advocate
wYes it happens with v13 as well.  I've tried --force and --legacy.. nothing seems to resolve the depreciated dependencies.
npm ERR!
npm ERR! While resolving: client@0.1.0
npm ERR! Found: axios@0.21.4
npm ERR! axios@"^0.21.1" from the root project
npm ERR!
npm ERR! peer axios@"^0.18.1" from box-ui-elements@13.0.0
npm ERR! box-ui-elements@"13.0.0" from the root project
npm ERR!
Let me reach out to that team and report back! Thank you for bringing this up.
Can you confirm what version of npm you are running?  You could consider using the --legacy-peer-deps flag like described here. We verified it works for running npm v6.4.13.
Thanks,
Alex
