I have a user who is being prompted to updated Box Tools, when they try to install a new version it says: "The older version of Box Tools cannot be removed. Contact your technical support group". When trying to uninstall from control panel it errors out. I then deleted everything I could find in File Explorer and in the Registry. Now it doesn't show as installed in control panel but still gives the error above.
Box Tools won't uninstall. Doesn't show as installed in control panel.
Sign up
Community access is available only with a Box Account.
Sign in with your Box AccountSign in to the Box Community
Sign in with your Box AccountEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
