Box Employee
May 23, 2025 9:27 AM UTC
Box hit an unexpected problem
Received this Popup.
"Unfortunately you will have to manually upgrade to the newer release once this issue i resolved. Please report this issue to the Box User Services Team."
Could not find Box Users Services Team.
What do I do -uninstall & re-install.
Why can I not access the box folders that were also saved on the PC? There is no Box folder anywhere.
    Box Employee
    Hi there,
    Welcome to the Box Community!
    For me to check, may I please have a screenshot of what it looks like on your end? Could you please confirm if Box Drive or Box Sync is currently installed in your machine?
    Looking forward in assisting you.
    Box Employee
    May 23, 2025 9:28 AM UTC
    Box Employee
    Any progress?
    All the folders that were synchronised between PC & Cloud no longer exist on PC!
    New Member
    Nov 20, 2025 3:58 PM UTC
    i have the same issue - i made a ticket - but don’t know when it will be solved?
