Box Drive System Extension Failed to Load on Big Sur
  • May 22, 2025
  • 2 replies
  • 89 views
Is there any light at the end of the tunnel from a developer standpoint on when we can get an update from Box to use the product on Macs with Big Sur installed??? It's been over 3 months...
Hi John,
Welcome to the Box Community!
Kindly check out our response and answer on this issue in other thread related to your use case:
https://support.box.com/hc/en-us/community/posts/360051323454-Box-Drive-s-system-extension-failed-to-load?page=1#community_comment_1500000009302
Thanks again for your patience and understanding and let us know if there's anything else we can help you with!
5 months later and it's still doing the same thing. I don't have an M1 chip in my Mac Book Pro...
