Box Drive’s system Extension Failed to load
  • May 22, 2025
  • 3 replies
  • 75 views
I had to Uninstall Box using CleanMyMac
I then had to reload a clean system (High Sierra)
There still seemed to be some broken threads for box in the Cache folder that I found using CleanMyMac again after the clean install
Once these were removed I reinstalled the Box drive without any incidence
I had deleted the Cache folder and uninstall box before this procedure without success
It seems that reloading a clean system folder made all the difference in my attempt to overcome this obstacle
Hi Michael,
Welcome to the Box Community!
Thanks for sharing your use case here. If you are continuously having issues running Box Drive on your computer, I would encourage that you open a support case with our Product Support team so they can help you investigate and resolve this issue with you.
Please go ahead and submit a support ticket on this page: https://support.box.com/hc/en-us/requests/new
Thanks for your participation in the Community!
I click on the request new link and am brought to a page that says:
Need Help?
And nothing else.
A year later (from when this thread was created), I'm also on High Sierra on a 2011 MacBook Pro and this message has started occurring only in the last week. Box had been working properly until then.
There's no entry for Box in System Preferences > Security & Privacy, not in any of the four tabs. I have restarted the computer multiple times, all to no avail. But then, without being able to enable the Box extension, I wasn't really expecting anything else.
