Box drive is not logging in and icon stays Grey
  • May 23, 2025
  • 7 replies
  • 94 views
When I use box via my google chrome browser it works perfectly. Box drive also runs fine on my desktop under windows 11 pro. But on my laptop box drive does not boot properly. I have to log in box drive rodes. but then nothing happens. No Box in explorer and the icon at the bottom right also remains gray.
- I did a complete reinstall (clean) of windows 11 and 10. I also reinstalled box drive several times
Default browser: Google Chrome
What can go wrong here?
Hi Peter,
Could you try the steps provided in this article to 'Manually Reset' Box Drive on your Windows computer?:
Let us know how it goes and if you have questions.
All the Best,
I did follow these instructions, with no result. :-(
But my problem is solved, with an old install file.
I delete box first. Installed box drive with an old file.
after logging in, the icon turns blue and  runs an update.
No problems so far! :-)
I've confirmed the same issue with a Windows 11 machine, Peter's resolution also worked for me.
I am having this same problem. The manual reset did not work for me.
Did you try an old install file? That worked for me after using that. Box is working great.
Hello, I've been unable to connect to box as well. I can't, however find any old install files to use.
9618909443987 could you send a link to the file you used?
Best,
Theo
https://app.box.com/s/7d6iafi9y3mkoh7zxtv2if19p0kblqhk
this should be the file Theo.
Good Luck!
