Box Drive: Does not work with company proxy
  • September 3, 2025
  • 2 replies
  • 319 views
I am using Box through webbrowser interface.
To improve usability, I wanted to also use Box Drive, but it does not seem to work with our company proxy server. If I connect at home without proxy, everything is fine.
I can do the Box Drive login process until I get the link to open the Box Drive app. But then nothing happens.
Can anybody tell me how to fix this?
  • New Member
  • September 4, 2025
The reason your Box Drive application is failing to connect is likely due to your company's proxy server blocking the application's communication, even though your web browser works fine. Your browser is configured to use the proxy, but the Box Drive ChoiceAdvantage application itself may not be, or the proxy is blocking the specific domains Box needs to complete its login and synchronization. The solution requires either manually configuring the proxy settings within Box Drive's configuration file or, more likely, having your company's IT department whitelist the necessary Box domains. Your best course of action is to contact IT and provide them with the list of domains to unblock.
  • Author
  • New Participant
  • September 4, 2025
Thank you for your reply.
But our company policy does not allow any Internet connection bypassing the proxy. So whitelisting is not an option.
Also, Windows is configured with system proxy and a properly programmed Windows app usually can use Kerberos to authenticate at the proxy and request user credentials.
We found that the Box Drive app is not properly authenticating at the proxy.
So can I configure the proxy manually somewhere? I could not find documentation or location of the config file. Preferrably without having to store user credentials but instead there should be a dialog asking me for the credentials every time I want to connect.
In the Box log, there is an entry:
“System.Net.WebException: The remote server returned an error: (407) Proxy Authentication Required.”
It looks like proxy is found, but the authentication is not handled correctly.
  • Author
  • New Participant
  • September 23, 2025
Does nobody have any insight or tip for me?
I found this information in the official support documents:
https://support.box.com/hc/en-us/articles/360043696434-Configuring-A-Firewall-For-Box-Applications-and-Services
If I understand that correctly, it says that the Box Drive application is basically capable of detecting the proxy and authenticating via NTLM.
Above we can see it sends the requests to the correct proxy, but does not handle the authentication correctly while interestingly the Box Drive Updater can connect correctly.
