Supercharge Box with Agentic AI: Introducing Box + StackAI
  • May 4, 2026
  • 152 views
  • New Participant
We've watched enterprise content management evolve from simple shared drives to sophisticated cloud platforms, and Box has been at the center of that shift for thousands of organizations. But even the most well-organized Box environment has the same limitation: the documents sitting inside it are static. They can't answer questions, route themselves, or synthesize insights on demand.
That's exactly why we're proud to announce the Box integration on StackAI.
You can now connect Box file storage directly to StackAI's no-code workflow builder to:
  • Ingest documents from Box folders into AI-powered knowledge bases
  • Route, classify, and process files automatically based on content
  • Build conversational assistants that answer questions from your Box-hosted documents
  • Trigger AI workflows when new files land in specific Box folders
  • Write back results (summaries, extracted data, generated reports) directly to Box
Authentication takes minutes and stays secure. No IT nightmares, no months-long implementation.
The Untapped Value Inside Your Box Environment
Box is trusted by organizations across financial services, industrials, life sciences, media, and the public sector for secure, cloud-native content management.
But by connecting Box to the StackAI workflow builder, you turn passive file storage into dynamic, queryable, automated intelligence. Here are five workflows organizations are building today.
Use Case 1: Intelligent Document Ingestion & Folder Routing
The Problem
Contracts, invoices, compliance filings, project reports…large organizations deal with thousands of incoming documents every day. Manual sorting is slow, inconsistent, and frankly a waste of skilled people's time.
The Solution with StackAI + Box
Build a workflow that automatically ingests new documents, classifies them using an LLM, and routes them to the correct Box folder based on document type, department, project code, or any custom taxonomy you define.
How it works:
  1. Trigger: A new file lands in a designated Box "Incoming" folder or is sent in via email
  2. Extract: StackAI parses the document (PDF, DOCX, scanned images via OCR)
  3. Classify: An LLM node analyzes the content against classification rules in your knowledge base
  4. Route: The workflow uses Box's Copy File or Upload File actions to place the document in the right subfolder (e.g., /Projects/2026/ClientName/Contracts/)
  5. If a set of specific documents are uploaded, the workflow will automatically email the designated manager with a link to the document in Box
Real-world pattern: A wealth management firm automated routing for 2,000+ monthly documents across 150+ directories. What previously required a full-time coordinator now runs autonomously with 97% accuracy.
Use Case 2: RFP & Proposal Response Automation
The Problem
Responding to RFPs means pulling from dozens of past proposals, capability statements, and project write-ups scattered across your file storage. Most teams are doing this manually, every single time.
Build an RFP Response Agent that handles the process end to end:
  1. Intakes an incoming RFP
  2. Breaks it into individual questions and requirements
  3. Searches past proposals in Box using Search For Content
  4. Drafts section-by-section responses with citations
  5. Uploads the draft back to Box using Upload File and emails for human review before it goes out
Real-world pattern: An engineering consultancy built a five-stage pipeline (summarization, outlining, drafting, quality review, final output) that cut proposal turnaround from two weeks to three days. Their reference corpus: 500+ past proposals, all stored in Box.
Use Case 3: Contract Analysis & Extraction
The Problem
Every contract review means a lawyer or paralegal spending hours combing through 30-100 page PDFs looking for renewal dates, liability caps, and non-standard clauses. It doesn't scale.
Create a Contract Intelligence Workflow that:
  1. Intakes new contracts
  2. Downloads and parses each document using Download File
  3. Extracts key metadata: parties, effective dates, termination clauses, payment terms, liability caps
  4. Flags non-standard language against a template stored in Box
  5. Uploads a structured summary back to Box using Upload File Version, preserving the document's full version history
Real-world pattern: A logistics firm automated metadata extraction across their entire tender repository. Their team can now answer "Which tenders have auto-renewal clauses expiring in the next 90 days?" in seconds.
Use Case 4: Compliance & Policy Assistant
The Problem
The policies employees need are in Box. But they're buried three folders deep, written in legal language, and nobody has time to hunt for them. So people either guess or they ask compliance teams for answers that should be self-serve.
Deploy a Compliance Chatbot that uses Search For Content to surface relevant policy documents and AI to extract precise, cited answers.
How it works:
  1. An employee asks: "What's our data retention policy for client financial records?"
  2. Search For Content identifies the most relevant compliance docs across your Box /Policies/ and /Compliance/ folders
  3. The AI reads the matched documents and returns a plain-language answer
  4. Every response includes exact citations (document name, folder path, relevant section) so nothing is taken on faith
  5. For broader queries, the workflow synthesizes across multiple documents to give a full policy overview
Real-world pattern: A venture capital firm deployed a three-tier compliance system: a first-line chatbot for instant employee queries, a second-line investigation tool for compliance officers, and a third-line report generator for audit-ready summaries, all drawing from Box.
Use Case 5: Automated Research & Reporting
The Problem
Analysts and research teams spend hours manually pulling from multiple documents to build reports that could, with the right setup, practically write themselves.
Build a Research Automation Agent that:
  • Searches your Box environment using Search For Content across keyword and semantic queries
  • Downloads and synthesizes information from multiple files using Download File
  • Pulls in external signals via web search, Salesforce, Snowflake, or any other connected integration
  • Generates structured reports: market analysis, client intelligence, clinical research summaries
  • Saves finished reports back to Box with consistent naming conventions using Upload File and Update File
Real-world pattern: A hedge fund automated their daily equity research briefing. The workflow pulls the latest analyst reports from Box, synthesizes key takeaways, and delivers a formatted email to portfolio managers every morning before market open.
The documents in Box already contain your organization's institutional knowledge. StackAI makes it living and active through AI workflows that are fast to build, built for enterprise compliance, and designed to handle real operational complexity at scale.
Ready to get started? Book a personalized demo here.
Learn more about StackAI and Box here.
