Is it possible to create a Hub and block AI tools on just the hub?
  • Apr 14, 2025 10:00 PM UTC
  • 1 reply
  • 87 views
thomasdeely Box
 For instance if a Client does not want AI enabled on their data.
1 reply
thomasdeely Box
  • Author
  • Sr. Community Manager
  • Apr 14, 2025 10:01 PM UTC
yes you can disable AI for a specific hub from the settings menu within the hub
