Not able to Create Box Note Using Markdown-to-Box Note API
  • Sep 1, 2026 2:06 PM UTC
  • 53 views
I am trying to test the Box API endpoint /2.0/notes/convert in Postman, which is used to convert Markdown content into a native .boxnote file in a target Box folder.
However, I am not receiving the expected output when making the API request. I would like assistance in understanding the correct request format, required parameters, headers, and any specific requirements for successfully creating a .boxnote file from Markdown content.
API Endpoint:
https://api.box.com/2.0/notes/convert
Environment: Postman
Expected Result:
The Markdown content should be converted into a native Box Note (.boxnote) and created in the specified target folder.
Actual Result:
The API request giving the below error (Screenshot attached)
Please provide guidance on the correct API request and any required configuration or permissions needed for this operation.
Are this APIs only available for higher tier subscriptions? If yes the description in the “Plan comparison” is misleading because it does not state which APIs are available per plan.
