Solved
Box Sign "Multiple signers and signing order" Approver and Order Issues
  • Dec 5, 2023 10:42 PM UTC
  • 3 replies
  • 726 views
I have tried to create a signer and and approver order, but it always takes the second email.
Referring to the attached code below:
  • When there is a order 1 & order 2, no emails send out
  • When there is a order 2 but no order 1 set, then the approver gets the email.
  • When there is a order 1 but no order 2 set, then the approve
  • When there is no order defined, the approver email sends.
I should note, that each email does work when pushed alone. We are using the python SDK
“signers”: [
“email”: signer_email,
“role”: “signer”,
“embed_url_external_user_id”: signer_email,
“password”: “xxxxx”,
“order”: 1
“email”: approver_email,
“role”: “approver”,
“order”: 2
Best answer by rbarbosa Box
Hi @Steonard, welcome to the forum!
Not considering the order, I think that is the expected behavior. The approval role is meant for approving the signature request, so it is triggered before any signer.
Typically I only apply the order to the signer roles. Both the approver and the final copy reader order are pre-set, the approver goes before any signer and the final copy reader after all signers. Also note that a signer is anyone that has an input to the document, and may not include a signature.
I confess I never tried to set an order to the approver or the final copy reader, and there might be some unexpected interaction there. Some testing is required.
Consider this sample code using the Next Gen Python SDK:
def sign_contract_step(
    client: Client,
    document_id: str,
    destination_folder_id: str,
    institution_email: str,
    student_email: str,
    dean_email: str,
    legal_email: str,
) -> SignRequest:
    """Sign contract"""
    # Sign request params
    source_file = FileBase(id=document_id, type=FileBaseTypeField.FILE)
    destination_folder = FolderMini(
        id=destination_folder_id, type=FolderBaseTypeField.FOLDER
    # signers
    institution = SignRequestCreateSigner(
        email=institution_email,
        role=SignRequestCreateSignerRoleField.SIGNER,
        order=1,
    student = SignRequestCreateSigner(
        email=student_email,
        order=2,
    dean = SignRequestCreateSigner(
        email=dean_email,
        role=SignRequestCreateSignerRoleField.APPROVER,
    legal = SignRequestCreateSigner(
        email=legal_email,
        role=SignRequestCreateSignerRoleField.FINAL_COPY_READER,
    # create sign request
    sign_request = client.sign_requests.create_sign_request(
        signers=[institution, student, dean, legal],
        parent_folder=destination_folder,
        source_files=[source_file],
        is_document_preparation_needed=True,
    return sign_request
And its usage in a main script:
def main():
    # Multiple signers and steps
    sign_contract_multi_step = sign_contract_step(
        client,
        CONTRACT,
        SIGN_DOCS_FOLDER,
        institution_email=SIGNER_A,
        student_email=SIGNER_B,
        dean_email=APPROVER,
        legal_email=FINAL_COPY,
    if sign_contract_multi_step.prepare_url is not None:
        open_browser(sign_contract_multi_step.prepare_url)
Notice in the example below that the institution is represented by the blue color in the left, and the student by green on the right, both are signers
Neither the approver nor the final copy reader can have inputs associated with them. If you do this, their roles will be adjusted to signer
The signature process goes like this:
  • First the dean approves the scholarship
  • Next the institution signs the scholarship
  • Next the student signs the scholarship
  • Finally the legal department receives a copy of the signed document.
Let us know if this was of any use.
Also the above example is detailed in one of our blog articles, you can check it out here:
And it is also part of a sign workshop, if you’re interested, with sample code and exercises (look for sign in the readme.md):
Cheers
View original
rbarbosa Box
  • Developer Advocate
  • Answer
  • Dec 6, 2023 11:04 AM UTC
    client: Client,
    document_id: str,
    student_email: str,
    dean_email: str,
    legal_email: str,
) -> SignRequest:
    """Sign contract"""
    # signers
        order=1,
        order=2,
        email=dean_email,
        email=legal_email,
    return sign_request
def main():
        client,
        CONTRACT,
        SIGN_DOCS_FOLDER,
Cheers
  • Author
  • New Participant
  • Dec 6, 2023 8:22 PM UTC
Ohh I get it. For some reason I thought approver was after the signer. It works as you talked about thanks so much!
rbarbosa Box
  • Dec 8, 2023 11:59 AM UTC
You’re very welcome @Steonard
Could you mark. my answer as the solution for others benefit?
Cheers
