Configure Notification and Security Settings on Box for Android
Access your app settings (Settings in the main menu) to set your notification and security preferences for the Box app. You will also find the amount of storage you have used listed at the top of the settings screen.
Notification Settings
cep2srme083ciwvhycrt0ar5txlfwrdx
Here you can choose when you will receive notifications from the Box app. Uncheck the boxes to stop receiving notifications.
Security Settings
5hu884v0hgre5yrm2atf8rqkkn56hya1
Uncheck Keep me logged in if you would like to be logged out of your Box account every time you close the Box app.
Enable Require passcode to set a 4 digit passcode that you will be required to enter each time you open the Box app.
If your device has fingerprint scanning capabilities (Android 6.0 and up), you can choose to unlock the app using your fingerprint instead. Enable the Require passcode setting and if your device has the capability, the fingerprint option will be displayed.
Folder Activity
455hm8zp39qxiejt3ab0wy4yhytv5hwg
Under Folder Activity, you can remove any Cached Files from your device. Cached files are temporary files that are created when you preview a file, and save you time when you preview the file again. Removing cached files will clear some storage space, but will also mean that you will need to re-load any previewed items.
If you enable Automatically upload files, Box will detect files stored on your device and upload them to Box automatically.
Version history
Revision #:
1 of 1
Last update:
‎01-19-2018 03:51 PM
Updated by:
Labels (3)
Contributors
More in this guide:
Go to Guide
