Box Tools vs Box Edit
Box Tools is the installer package that installs both Box Edit and Device Trust functionality. The Device Trust component is only used if Device Trust is enabled for your Box account.
Deploying Box Tools on Windows
This information applies to physical Windows environments. For more information on using Box desktop applications in virtual environments, see Using Box in Virtual Environments.
Single-user vs machine-wide installations
We offer two variations of Box Tools: single-user and machine-wide. The functionality between the two variations is the same but they install the programs in different locations and support different configurations.
Single-user
The standard Box Tools .exe installer available from https://www.box.com/resources/downloads installs Box Tools under the user's profile and should only be used for single-user machines. The single-user .exe installer does not require administrative rights and is designed to be easily installed by end users.
The single-user version installs into the following locations on the computer:
  • C:\Users\USERNAME\AppData\Local\Box\Box Edit
  • C:\Users\USERNAME\AppData\Local\Box\Box Local Com Server
The single-user installation is not recommended for mass deployments of Box Tools.
With the single-user installation, both Box Edit.exe and Box Local Com Service.exe should be running as the end user.
Machine-wide
The machine-wide .msi installer installs Box Tools as a machine-wide program and supports multi-user machines. Any user on the machine can use Box Tools functionality (Box Edit and Device Trust) if the .msi installer is used. The machine-wide installer requires administrator rights to install Box Tools.
After installing with the machine-wide version, users will need to log out of Windows and log back in again before Box Edit will be enabled for those users.
The machine-wide installation location:
  • C:\Program Files (x86)\Box\Box Edit
  • C:\Program Files (x86)\Box\Box Local Com Server
The machine-wide installer is recommended for mass deployments of Box Tools.
With the machine-wide installation, Box Edit.exe should be running as the end user and Box Local Com Windows Service.exe should be running as the SYSTEM user as a Windows service.
System Image Deployments
If you are using a system image to deploy Box Edit, verify that the Box Edit Documents folder on your source machine (C:\Users\USERNAME\AppData\Local\Box\Box Edit\Documents) is empty before capturing the image.
Deploying Box Edit on macOS
The Mac installer for Box Tools can be used with Mac deployment tools.
Prior to installing anything, the installer will do any necessary uninstalling, getting rid of any outdated plugins and .app files that might cause problems with Box Edit. The installer will then create the folder "~/Library/Application Support/Box/Box Edit/" and add the .app files "Box Edit.app" and "Box Local Com Server.appto that directory.
After this, the installer will launch both .app files, making sure that they are both running before exiting the installation. The .app files will register themselves to start up at login time for the user that they're running for.
Note: If the .app files are not started for a user, the web app won't be able to verify that Box Edit is installed, and the user will be prompted to install Box Edit when they try to edit a file.
If you are using a deployment tool other than Casper Suite, or deploying Box Edit using a custom installer, be sure that the two .app files have been placed in the appropriate directory, and be sure to either start running them (as the user who will be logging in to that particular machine) or set them up to start running at login.
Box Tools DNS, Proxy, and Browser Configuration Guidelines
Box Tools uses a loopback network interface connection between the browser (Box.com) and the desktop. This interface may require you to configure your network to support Box Tools.
In addition to the information below, Internet Explorer may require additional configuration
Box Tools v4:
Box Tools v4 requires the ability for browsers (Box.com) to communicate with the Box Local Com Server by making requests to 127.0.0.1:17223 (or 127.0.0.1:17224 if port 17223 is occupied) over HTTP. The ability to communicate to 127.0.0.1 over HTTP is acceptable by the following w3c standard.
DNS:
Because Box Tools v4 uses the 127.0.0.1 loopback address, no DNS configuration should be needed for Box Tools v4.
Proxy:
If the proxy configuration is specified by a PAC file or a wpad.dat file (i.e., a PAC file published via DNS WPAD discovery), requests to http://127.0.0.1:17223 and http://127.0.0.1:17224 should be allowed to connect DIRECT.
An example PAC file code snippet:
// If the protocol or URL matches, send direct.
if (shExpMatch(url, "http://127.0.0.1:17223") || shExpMatch(url, "http://127.0.0.1:17224"))
        return "DIRECT";
Note: "Direct" should be in all uppercase: DIRECT
Alternatively, you can configure your operating system to bypass proxies for 127.0.0.1 requests:
On Windows:
  1. Navigate to Control Panel > Internet Options > Connections > LAN Settings (or Settings for a selected Connection)
  2. Check the Bypass proxy server for local addresses box
On Macs:
  1. Navigate to System Preferences > Network > select your connection > Advanced… > Proxies.
  2. Add 127.0.0.1 to the box under Bypass proxy settings for these Hosts & Domains.
 (screenshot from macOS 10.11.6)
