Unsyncing a Folder
If you have a Box folder marked to Sync to your desktop but would no longer want it to be Synced, there are a number of ways to remove that folder. Choose one of the options below to Unsync your desired Box folder.
Method 1:
  1. Highlight the folder
  2. Select the Details tab on the right
  3. Toggle the Sync to Desktop option
Method 2:
  1. Select More Options button for the folder
  2. Hover over More Actions
  3. Select Unsync
Method 3:
    1. Select Synced menu
    2. Select More Options button for the folder
    3. Select Unsync this Item
Version history
Revision #:
3 of 3
Last update:
‎04-23-2018 02:03 PM
Updated by:
Labels (5)
Contributors
Users online (318)
