Once you have installed Box Edit, you can open and edit documents directly from Box. To open files with Box Edit:
  • Right-Click a file (or click the ellipses (...)) to open the More Options menu.
  • Click Open With... If there is more than one application with which you can open the file, you will have the option to select the appropriate application.
    box edit - 1
You can also open and edit documents after previewing them. To open files with Box Edit from the preview screen:
  • Click the file to open it in preview
  • Click Open. If there is more than one application with which you can open the file, you will have the option to select the appropriate application.
