Opening or Searching for Box Notes
From within the Box Notes web interface or desktop application, you can open any Box Note that you have access to. You can also search for any Box Note you have access to.
Opening Box Notes
To open a Box Note:
  • Click the folder icon in the upper right corner of the toolbar.
  • In the pop-up that appears, select the Box Note you would like to open by clicking the bubble beside its name. You can also search for a Box Note using the search bar in the pop-up. Click Choose once you have selected a Box Note.
If you'd like to return to a previously opened Box Note, you can easily access it from your Recents.
Searching Box Notes
To search for a note:
  • Click the search icon in the upper right.
  • Enter your search terms in the search bar that appears.
  • Click on a result to open that note.
Version history
Revision #:
2 of 2
Last update:
‎10-26-2017 11:38 AM
Updated by:
Labels (4)
Contributors
Users online (129)
