getaddrinfo ENOTFOUND upload.box.com upload.box.com:443
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    That error will generally mean that the remote host (upload.box.com) cannot be resolved on your system. If you're running off of localhost some of the general guidance I can see if to add a localhost entry to your hosts file, such as by doing the following:
    1. From a terminal, run sudo vi /etc/hosts
    2. Add 127.0.0.1 localhost
    Hope that helps,
    Jon
    0
    Comment actions Permalink
