function exec in php run Box CLI
SOLVED
Go to solution
Highlighted
New Contributor
I have use exec in PHP run Box CLI
I have install box cli  on ubuntu: "npm install --global @Box/cli "
Result Error: could not initialize cli home directory on ubuntu
Please help me!
2 REPLIES 2
Highlighted
Box Employee
Re: function exec in php run Box CLI
Hi @huunghia , when running PHP exec the Path and user permissions are often different than when accessing the shell directly. It's hard to debug from our end to be honest, I am sorry.
It might be easier for you to make API call directly using the JWT token. We have some documentation in PHP available here.
https://developer.box.com/guides/authentication/jwt/without-sdk/
Developer Advocate @ Box
Highlighted
New Contributor
Thank you,
Because our client asked to use the cli box, so I used PHP exec.
We will make API calls directly with the JWT token
