Webhooks at organization level
New post
Comments
1 comment
  • mbehn-box
    Hi
    The Webhook V2 functionality can only be applied at the folder or file level. If you are needing to be notified for events across the organization, I suggest using the events endpoint. The difference is that events need to be pulled FROM the API and cannot be sent to an endpoint you manage (like webhooks are). You can read more about the enterprise events endpoint from our developer site here:
    https://developer.box.com/reference#get-events-in-an-enterprise
    0
    Comment actions Permalink
