Webhook v1 not working
Answered
New post
Comments
2 comments
  • everuser
    I have the same problem 😞
    0
    Comment actions Permalink
  • mbehn-box
    Hi Miguel,
    If you are working with a V1 webhook that you created in the Developer Console, you will need to contact Box Support to enable the Webhook. Another option is to use Webhooks V2 which does not require Box Support to enable. You can see more about V2 webhooks here: https://developer.box.com/v2.0/reference#webhooks-v2.
    0
