Utilizing Chrome Extension for oauth verification
Answered
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    No, the SDKs are not specifically required to work with OAuth 2, you can do it all directly through the Chrome extension. If you have a way of redirecting the user to the Chrome extension after they sign in, you can extract the code that is on the query string and then make an HTTPS POST request to Box to exchange that for an access token. That will give you the token that you need to send to the Box APIs to authenticate the session. The only thing that I would caution you on is that you will have a very broadly scoped access token that gives direct access to the user's content. Having that stored within any environment that can be monitored is not a best security practice. The token lasts for an hour before it will need to be refreshed, so there is limited exposure after that time.
    Hope that helps,
    Jon
    0
    Comment actions Permalink
