Comments
2 comments
  • jcleblanc
    Hi ,
    I took a look over the docs and you're right, what's there could be a bit confusing for what the config file actually is.
    The config is essentially a file that you create (e.g. config.py) that houses a few variables that are needed for the app. The contents of the Python config would look like this:
    # Auth config
    client_id = 'YOUR CLIENT ID'
    client_secret='YOUR CLIENT SECRET'
    redirect_uri = 'http://127.0.0.1:5000/return'
    That's the config.py file that is being referenced in the docs. I have also added a more detailed explanation to step 1 of the docs to walk through that content as well.
    I also have a number of working application examples in Python (JWT & OAuth) here if you want to see a working example. I'm working on moving those over to the docs as well.
    Thanks,
    Jon
    0
    Comment actions Permalink
  • tcapretto
    Hi
    Thank you for your contribution. I am sorry but I am still a little lost on how to proceed. I'm sure it is because I'm new to Python.
    I copy your code, using my CLIENT ID and CLIENT SECRET.
    However, when I try to run the application, nothing happens.
    I am using "app.run()". Is that ok?
    This is what I get.
    app.run()
     * Serving Flask app "" (lazy loading)
     * Running on http://127.0.0.1:5000/ (Press CTRL+C to quit)
     * Environment: production
       WARNING: Do not use the development server in a production environment.
       Use a production WSGI server instead.
     * Debug mode: off
    0
