Using OAuth2 with JWT without a Box SDK
Answered
New post
Comments
2 comments
  • mwiller
    Hi  — you may find the guide at https://developer.box.com/v2.0/docs/construct-jwt-claim-manually useful.  It walks through constructing a JWT manually and using it to authenticate with the Box API.
    0
    Comment actions Permalink
  • dh-challenge
    I had to do this as there's no PHP SDK.
    I use a library to help:
    use Emarref\Jwt\Claim;
    use Emarref\Jwt\HeaderParameter;
    And in my Box class constructor...
    function __construct($boxJson)
    		$this->Curl = new Curl;
    		$boxJson = utf8_encode($boxJson);
    		$boxJson = json_decode($boxJson);
    		$uniqueID = uniqid('???');
    		$token = new Emarref\Jwt\Token();
    		$token->addClaim(new Claim\Audience('https://api.box.com/oauth2/token'));
    		$token->addClaim(new Claim\Expiration(new \DateTime('60 seconds')));
    		//$token->addClaim(new Claim\IssuedAt(new \DateTime('now')));
    		$token->addClaim(new Claim\Issuer($boxJson->boxAppSettings->clientID));
    		$token->addClaim(new Claim\JwtId($uniqueID));
    		//$token->addClaim(new Claim\NotBefore(new \DateTime('now')));
    		$token->addClaim(new Claim\Subject($boxJson->enterpriseID));
    		$token->addHeader(new HeaderParameter\KeyId($boxJson->boxAppSettings->appAuth->publicKeyID));
    		$token->addHeader(new HeaderParameter\Type('JWT'));
    		$token->addClaim(new Claim\PrivateClaim('box_sub_type', 'enterprise'));
    		//encrypt the JWT
    		$algorithm = new Emarref\Jwt\Algorithm\Rs256();
    		$encryption = Emarref\Jwt\Encryption\Factory::create($algorithm);
    		$privateKey = openssl_get_privatekey($boxJson->boxAppSettings->appAuth->privateKey, $boxJson->boxAppSettings->appAuth->passphrase);
    		$encryption->setPrivateKey($privateKey);
    		$jwt = new \Emarref\Jwt\Jwt();
    		$serializedToken = $jwt->serialize($token, $encryption);
    		//get the token
    		$TOKEN_RECEIVED = false;
    		$TOKEN_ATTEMPTS = 0;
    		do {
    			$this->Curl->post('https://api.box.com/oauth2/token', array(
    				'grant_type' => 'urn:ietf:params:oauth:grant-type:jwt-bearer',
    				'client_id' => $boxJson->boxAppSettings->clientID,
    				'client_secret' => $boxJson->boxAppSettings->clientSecret,
    				'assertion' => $serializedToken
    			if (isset($this->Curl->response->access_token)) {
    				$TOKEN_RECEIVED = true;
    			} else {
    				$TOKEN_ATTEMPTS++;
    				sleep(5);
    		} while (!$TOKEN_RECEIVED and $TOKEN_ATTEMPTS < 6);
    		if (!$TOKEN_RECEIVED) {
    			ob_start();
    			var_dump($this->Curl->response);
    			$TokenErrorText = ob_get_clean();
    			$TokenErrorFile = 'logs/BoxTokenError-' . date('d-m-Y His') . '.txt';
    			file_put_contents($TokenErrorFile, $TokenErrorText);
    			exit;
    		//set the authorization header
    		$this->AccessToken = $this->Curl->response->access_token;
    		$this->Curl->setHeader('Authorization', "Bearer $this->AccessToken");
    		$this->Curl->setHeader('Content-Type', 'application/json');
    0
