Uploading Files and Folders to Box
New post
Comments
4 comments
  • LoCortes
    Hello Sahil,
    I think that the problem is the fact that, as you said, is a simple HTML on your desktop. So... it is not running on any web server / web application and it does not have a domain that can be used as Origin.
    Regards,
    0
    Comment actions Permalink
  • Sahil_Monga
    Hi LoCortes,
    I tried it by hosting the file on IIS Web Server but still the error is there.
    0
  • LoCortes
    Hello there Sahil,
    have you added on the CORS configuration the IP of your server or maybe localhost? probably that is the last step you need to perform the call succesfully.
    I will try it myself and see if it works.
    Thank you
    0
  • Dindayal Pandey
    I am still facing this issue, any answers for this one...
    2
Post is closed for comments.
