Unable to run Box CLI
I am new to box. Recently installed Box CLI but when I run the box.cmd it flashes for a moment and disappears.
What am i missing here?
Hi ,
Just a note - it has been a while since I've worked with the CLI on Windows, but can you try loading up a regular command prompt and typing box and hit enter please? The CLI should install into your terminal / command prompt and allow it to be used that way. You'll just type in the commands to interact with the CLI from there.
- Jon
Comments
1 comment
