UNC support for BOX
New post
Comments
1 comment
  • jcleblanc
    Hi ,
    The way that Box will structure it's upload path is based on folder IDs. One of the main reasons why we don't use full paths is because a path to a file might be very different from one user to another, depending on collaboration structure.
    For file uploads from local systems to that folder ID within Box, we'll just expect a read stream during the upload. How you pull in that read stream is up to you.
    - Jon
    0
    Comment actions Permalink
