Total space amount allocated and Total space used at organization level
New post
Comments
3 comments
  • Kourtney
     By organizational level do you mean you want to know the amount of space allocated and used for each user in the enterprise or how much storage your enterprise is using total?
    If you want this data for each user, you could use this endpoint: https://developer.box.com/reference#get-all-users-in-an-enterprise, which will return space_amount and space_used.
    Best,
    Kourtney
    Box Product Support
    0
    Comment actions Permalink
  • Bharath_N_V
     yes we want total space allocated and total space used at enterprise level.
    0
  • Kourtney
     Unfortunately I'm not aware of a way to currently get this information via the API on the enterprise level. I know this information is exposed on the insights tab of the admin console via box.com, but this would be a great feature request to submit at pulse.box.com!
    0
