Task assignment issue
New post
Comments
1 comment
  • Jason
    Hi ,
    Do you receive an error code back in the response from the API? Or any other type of error? Developer accounts aren't restricted from creating tasks.
    More commonly, this can happen if the task assignee is not yet a collaborator on the file or folder. Do you know if the task assignee is a collaborator already? It may be easier to visualize the proper workflow and sequence of API calls if you try to assign a task through the UI at Box.com.
    Thanks,
    Jason
    0
    Comment actions Permalink
