Shared Link without expiration
Answered
New post
Comments
3 comments
  • jcleblanc
    Hi ,
    This is most likely an enterprise-wide content setting. If someone with admin access to your Box enterprise can go to the Enterprise settings content & sharing page (alternately from the admin console go to Enterprise Settings -> Content & Sharing), then scroll down the page until you get to the "Auto-Expiration" section. In that section you'll see options for when to auto-disable shared links. Most likely that's the culprit here.
    - Jon
    0
    Comment actions Permalink
  • eladfrnclz
    Thanks for the quick answer Jon.
    So does this means that when I am using the API and calling the create shared link (and not specifying the 'unshared_at' param) I am not setting any expiration?
    Thanks
    0
  • jcleblanc
    Hi ,
    That's correct, if no unshared_at parameter is set in the API then it'll use the default settings of the enterprise.
    - Jon
    0
