Search API Problem
New post
Comments
2 comments
  • jcleblanc
    Hi ,
    Nothing you're doing wrong from what I can see what your explanation. The search API currently functions slightly differently than the web app in that the search query string will be matched as full or part of the file name, then return all results without ranking. There are some improvements being developed that should impart better categorization of the result set, but those are not live yet.
    For the latest folder, that is most likely due to the indexing delay. If you upload / create new content within Box there will be a 5-10 min indexing delay before it's available via search. My guess is that's probably what's happening here.
    - Jon
    0
    Comment actions Permalink
  • Ibrahim Karayel
    I'm trying to make a call via box search API everything looks fine but it seems search API returns the wrong result. The filter not working as expected.  I do expect one file because I have only 1 file with the prefix FilePrefix_on_07132022 but it returns 200.
    My filter : FilePrefix_on_07132022*
    but it returns all other files with FilePrefix_on_08*.  too
    I wonder if using '*' works or not. It seems not
    Paramters send
    0
Post is closed for comments.
