Salesforce and Box ID field
Is there a declarative solution to get a Box Id to a custom record in Salesforce?
Hi ,
Thanks for your question! What do you mean by declarative solution? I think you're looking to associate a particular box folder to a custom record - if so, try createFolderAssociation from the toolkit:
https://developer.box.com/docs/box-for-salesforce-developer-toolkit
If you're trying to do something else, could you explain a bit more on what you're trying to do? Thanks!
Kind Regards,
Jason
Comments
1 comment
