Re: About Box Sync
Hi.
A Excel-XLSM is checking data from Box-Sync folder - but I didn't know, if the data was synced and up-to-date.
How can I check the sync-status of a folder within an API-call out of my Excel-XLSM?
Hi ,
There are a few items here, depending on what you're after:
- If you're looking for the sync state (whether something is set to sync with Box Sync) then you'll be able to fetch the sync-state value in the folder object. More info here.
- If you want to capture when a folder has been synced, you can potentially do a few things:
- If you listen for the ITEM_SYNC event, that should give you information on when an item is synced. More info here.
- I'm not 100% certain of this, but it's possible that the last_modified date info is updated when content is synced. I'd very that first, but it's another possible avenue.
Thanks,
Jon
Hi .
Thanks for feedback .. my only problem is, that I didn't get it managed to create such a request out of an Excel-scirpt. I want to avoid any popups for the users (to sign-on at box, etc.). So for authorization I should use an box-API/predefined Token to access the folder-information .. but I didn't manage this in Excel and didn't find any examples. of how to do it ...
I think, I have to search for another "solution" ...Thanks so far for your feedback!
Regards Heiko
Comments
2 comments
